I already had that in my Chrome favorites. I know about it. That's nice but then you're phone is laying there out of sight and view.
What I wanted to use was a wireless charging phone mount. Proclip has the attachment and wireless charging pad for it, the problem is that it has to be connected to the accessory socket. It does NOT have a USB cable. That's why it won't work for this car, because the accessory socket is ON all the time. If for some reason, you leave your phone in the car on the magnetic pad, it will drain the battery.
The flat pad you linked is different, it has a harness that is connected behind the accessory socket, but I think that connection cuts power after the car is off
They removed the accessory socket under the radio that would cut power after the car turned off.
I'm not interested in a flat pad, it doesn't serve my purposes as I want to be able to look at the phone while driving
So if I want to use my phone on a mount, I have to connect it to USB like the photo below
