41 - 43 of 43 Posts
Yes, Robert`s instructions, but unfortunately i can no longer see the outside temperature which is a feature i wanted to have.
Let me know if you find a way to overcome this.
Hello. I fitted new 2006 10 pin display to my 2005 mazda as per instructions from Robert and I have everything displaying including Ambient Temp. Only thing i can suggest to you is either there is an issue with your display or maybe try swapping
Can Bus cables + and - and see if that helps.
Thanks to all who contributed to this thread with your valuable info. Saved my day.
Hello everybody ,
Diagram by Mr. Robert need to be correct
I found that gnd should connected to number 23 (Attached picture)
Veo dos pachas en la imagen me podrĂ­as dar un poco de ayuda esa pacha es la que viene con el radio Android. De hay es que tengo que tomar las lĂ­neas mensionadas
41 - 43 of 43 Posts
