I'm curious if this is possible, even though I know the wheels would not be "optimal" for either vehicle. I have an 05 Mazda6 with stock 17" wheels. I plan to buy a 2015 mazda6 in the next year or 2, so I'd love to be able to get a set of snow tires/wheels that can I use for the new car as well.
I've looked at 16" wheels for the winter set, since they are cheaper and generally seem like a better snow option. I'm aware that the 05 in a 16" uses 205/60R16 tires, and they need to have a load rating of 91+. Tirerack has a set of 215/60R16 (95T, 6.5" rim width, 26.1" diam) Blizzak WS70s that I would like to use, since they are well rated and on sale.
I gather that I will need a wheel with an offset of at least 50 mm to use it on my 1st gen? One set I was looking at are:
Sport Tuning T9
Offset: 53mm
Backspacing: 6.10"
Bolt Pattern: 5-114
Rec. Tire Size: 205/60-16
Weight: 17.05lbs.
Construction: 1pc. Gravity Cast
Are these wheels garbage? Would this combo fit my car? Tirerack seems to think that anything other than a 205/60-16 will not fit my car.
Second, would these work in the 3rd gen 6? Or should I abandon that dream entirely?
I accidentally posted this in the wrong section originally, but don't know how to delete that thread.
Sport Tuning T9
Offset: 53mm
Backspacing: 6.10"
Bolt Pattern: 5-114
Weight: 17.05lbs.
