Hi,
Anyone top off their R134A refrigerant and see it looking Green??
I'm wondering if its die for leak detection as I've honesly never seen it be green before.
Its an 06 with Auto Climate, it blows 40F at the dash full cooling set at 60F.
Low side pulls 22 psi, high side 190 ~ 225 as it gets hot. Ever since i've owned it, it cycles the compressor never just staying on. Pretty sure its designed that way for MPG/Efficiency etc... Off its sitting at roughly 50PSI...
My 95 camry on R134a runs a higher head pressure at 250 PSI and pumps out 30F from the dash. It doesn't cycle every 30 seconds like this does...
Is your R134A Green?
What temps do you get at the dash on full cool setting?
What are your pressures?
