Squeak sound when locking doors?
12K views 14 replies 7 participants last post by  tommyz23
#1 ·
Has anyone else had this happen?
When the doors lock they sometimes make a squeak sound.
'09 GT.
#2 ·
Nope...just a crisp click sound. Could it be temperature related? Maybe expansion and shrinking of the plastics from hot and cold weather that might cause rubbing???
#3 ·
I noticed it a while ago. It doesn't seem to matter whether it's warm or cold out.
It seems to happen only when I lock the doors. But, when I unlock then re-lock the doors it will not do it the second time. That's the problem. It will be hard to get it to happen at the dealer.
#4 ·
Can you isolate the noise to being at the lock next to the handle, latch in the door jamb or somewhere behind the door panel. Maybe just needs a little lubrication. It must be relubing (haha...sorry for the bad choice of words) it a little when you lock it the first time. Thats why you might not hear it the second time.
#6 ·
Yes i've had the squeaking sound for several years in my 04' 6s. It's like a high pitch squeak that happens when hit the lock switch. It doesn't seem to affect the locking mechanism, so I just left it alone.
#8 ·
This happens to me, on unlock only, seems to be isolated to my rear driver's side door. '10 GS.
Going to try lubricating it and see if that helps any.
#10 ·
Mine did that on the front passenger door. I took it in to the dealership and they said it was a faulty door actuator. Extended warranty covered the $200 and some change part and no more noise now.
#14 ·
now my right rear one is starting to "talk".... time to call the extended warranty again.
