I already cancelled my dyno arranged by the Mazda 3 group because the shop that's doing it told me it's only a 2 roller dyno. But, I remembered reading about how using the handbrake at speed cuts power to the rear wheels. Now I'm looking at the tech highlights info on the AWD system. First, it has a diagram which shows the parking brake switch/position as one of the inputs controlling AWD torque. Then under AWD / Normal Control it says:
"If a parking brake signal input to the AWD CM indicates, the module controls the torque transmitted to the rear wheels."
Then I found an early review of the pre-production MS6 which says:
"Yank the emergency brake in the new Mazdaspeed6 at speed and the car's all-wheel-drive system automatically disengages drive to the rear wheels." This is in reference to inducing drifting with the handbrake.
So, I'm wondering if it is theoretically possible to turn off DSC, put on the parking brake, and get a dyno done based only on power to the front wheels. If so, might it not provide some indication of the amount of power lost in the AWD system? Obviously, it would be unwise to try this on a 2-roller dyno 'cause what if the AWD CM changed it's tiny mind for some reason and started tranferring large amounts of torque to the grounded rear wheels. And, I imagine that the AWD system reduces power to the rear wheels at some point in the dyno run anyway. But, like I said, just wondering.
