Oil Pan Replacement
1 reading
3.3K views 6 replies 3 participants last post by  sadj2885
#1 ·
Anyone know where i can get a how-to or the Mazda shop manual for replacing the oil pan?
#2 ·
You will likely need to buy the whole FSM, but you can get them from you Mazda dealer, no one has made a how-to that I know of. But if you do yours, it would be great if you made one :D
#3 ·
Ha. ill be lucky if i can do it to begin with. Im not sure when ill have time to do it either. I got the new pan, but i dont have access to a lift at all times. Im almost 2k past my oil change and on top of that the other day my battery died for the second time this year.... 90k miles and ive had so many problems. Im ready to buy a new car at this point. Once i fix EVERYTHING, im puttig it up for sale, i cant afford to keep fixing it.
#5 ·
The drain plug is stripped apparently as per oil change place. Which i don't see how its possible because i have that valve thingie, i forget what its called. And its leaking on the side facing the rear. I think its just the gasket, but why not replace the whole thing if its the plug that's stripped too.
#7 ·
The one with instructions on how to replace the oil pan on a 2003 6 3.0
