I have exactly the same problem with my 2015 CX-5 after installing the December 2024 update to the SD card. I contacted Mazda and this was their reply:
If the SD card card is recognized by your PC and Toolbox, but not by the MZD Connect in your vehicle, please check the software version in your vehicle. Proceed as follows:
- SETTINGS> SYSTEM> ABOUT> VERSION INFORMATION
If you are using a version below the 74.00.XXX, please contact your dealer for a system update.
Perform a factory reset on your Mazda Connect system:
- SETTINGS> SYSTEM> FACTORY RESET
Please note that all data currently stored in the system will be deleted. These include:
- paired phones
- Connected Wi-Fi networks
- Phone book
- destinations
- Radio favourites
- Display settings
If, despite the above tips, the problem still persists, and you can access your SD card using your PC, please send us the following information so that our specialists can investigate the issue.
We require a
full diagnostic of your SD card including the signature files, which can be compiled via Toolbox:
- Start Toolbox and connect your SD card.
- Log in with your account.
- Go to Settings > SD diagnostics.
- Run diagnostics and, after it is done, and you see the results, underneath, click on "Check signature files".
Save the results in a text file.
Please also send us the following data:
- A copy of the log files of the Toolbox, found under C:\Users\USERNAME\AppData\Roaming\Mazda\log
- A copy of the http_dump folder of Toolbox, found under C:\Users\USERNAME\AppData\Roaming\Mazda
- A screenshot of any error message.
- A copy of the license folder of your SD card, found in the root directory of your SD card when connected to a computer.
Please compress the files in one or several
.zip files.
If your SD card is not recognised by your PC and Navigation system, please contact your Mazda dealer and request a new SD card.
If you have any other question, please contact us again and indicate us the VIN of your vehicle.
My version is 70.00.XXX so needs the firmware update. Mazda charge ÂŁ150 for this so I am trying to obtain the EU version of the file to do it myself (I am an experienced computer technician). The factory reset did not improve matters. If I'm able to obtain the upgrade, I'll report back, but to me, it seems like Mazda have issued a faulty SD card update
