Found a 3076R for a good price just needing to find out if these specs are right or not for it.
GT3076 Ball Bearing Turbocharger!!
Oil & Water cooled
8 blade propeler
Compressor Specs :
4" Compressor Inlet
2.126" or 54mm inducer
2.755" or 70mm Major
2.5" Outlet
Compressor .70 A.R.
Compressor 52 Trim
M24 / T4 Compressor Housing
Turbine Specs :
T25/T28 Type Turbine
T25 4 bolt flange
Turbine .86 A.R.
Turbine 76 Trim
2.079" or 52.80mm Major
M3 Turbine Housing
Exhaust Outlet Flange with 5 bolt design
Come with 8lb's adjustable internal Wastegate can also be modified to use external wastegate.
Suggested for 1.5L to 2.3L engine up to 200-500HP
also if these pictures look like the Garrett 3076 or a knockoff of some kind............thanx for any help.
Oil & Water cooled
8 blade propeler
Compressor Specs :
4" Compressor Inlet
2.5" Outlet
Compressor .70 A.R.
Compressor 52 Trim
Turbine Specs :
T25 4 bolt flange
Turbine .86 A.R.
Turbine 76 Trim
M3 Turbine Housing
