Engine (and radiator) overheated off and on. Refilled and was fine for awhile. Recently, blowing cold air when running the heater. Engine gets hot, but not the radiator, no pressure when carefully removing overflow cap. Replaced radiator, water pump, thermostat and did a heater core bypass. Fans are working fine. Refilled, no leaks. However no circulation of water (using h20 for test run). Upper radiator hose is bone dry. Ran engine to the point where water should be circulating but it is not. I added a gallon of water, but reservoir level is not dropping and there is absolutely no movement there. Removed thermostat. Nothing moving through engine.
