AC Compressor mounting bolt size???
2.6K views 1 reply 2 participants last post by  Ignatius Reilly
#1 ·
I just went through and replaced the tensioner and idler pulley and belt only to find out that wasn't my issue. I found out my bottom two ac compressor mounting bolts are totally missing which is causing the pulley to be misaligned, which is causing my belt to slip off. I desperately need the bolt size. Please if anyone can help.
#2 ·
Would it be possible to go pick one up at the junkyard? If you have a V6 I'd imagine bolts from a Fusion and probably most other Duratec Fords would work. If 4 cyl then same for Mazdas and Fords with the 2.3/2.5.
