Ok wise ones this is a goodie. I have searched and found nothing like this problem.
New motor is in to replace the broken one (another story) and the darn thang won't start. Motor cranks over and just floods. if I unplug the injectors and take the plugs out then earth them to chasis I get one spark maybe two while cranking continually. So.... no problem with fuel just no continuous spark. I have swapped out coil pack, leads, crank angle sensor and cam angle sensor (have the original set plus the set that came with the new motor). It almost seems like the imobilizer is not recognising the keys. Anyone else had problems with starting when the car has been left with no battery for about 3 weeks? due to the one or two sparks I get enough combustion to stop the motor dead in its tracks. It may be possible the timing is wrong... who knows with an import, but there shoud still be continuous spark while cranking the motor.
VERY DEPRESSING!!!!
If you solve this a spun con rod and good cyber woman is yours. LOL
edit... more info... it almost fires and then the lights go off and the guages go full deflection and then back. I tried a different battery and same problem.
Cheers.... Mark
VERY DEPRESSING!!!!
Cheers.... Mark
