I was wondering if they make any performance intake manifolds. Do they have any made for our car that are bored out and polished, or do we have to do it all ourselves?
you can use this to polish your intake manifold http://www.autogeek.net/motplaspol.htmlI was wondering if they make any performance intake manifolds. Do they have any made for our car that are bored out and polished, or do we have to do it all ourselves?[/b]
That might be one of the worst responses I've ever seen on these boards to a legitimate question.you can use this to polish your intake manifold http://www.autogeek.net/motplaspol.html
and maybe this to port/bore it http://www.sears.com/shc/s/p_10153_12605_0...20070921x00003a
:slap:[/b]
:slap:[/b]
Sorry I have had enduser delight all day and needed a good laugh I wasted 20 min of my life on the phone with a lady who kept unplugging the pbx instead of my router so I have to keep calling her back and I keep asking her wtf is up with the phoneThat might be one of the worst responses I've ever seen on these boards to a legitimate question.Front1ine, an intake manifold from the 6s has been donated to a company (forgot which) by Sheldon of Mazmart here on the boards to get something going for you guys. It may take quite a while for this to happen though, so patience certainly is required.[/b]
they are not cheep best look at a junk yardSpeaking of this, say someone has thrashed their plastic intake manifold from consistantly taking it off and puting it back on. How much would a new one cost? Is this a just ask Tiffany or Mazdamart question? If I buy a new one, I am definitly going to sand out and polish the inside of my old one to try to ever so slightly increase the volume of air that it can hold. Then of course make some gaskets, look for CEL's, and dyno. It is amazing how this car reacts to small changes in Air/Fuel/Timing changes.[/b]
Very true, and that is the project I donated to with some other members.. I totally forgot, I need coffee now! :yesnod:are not cheep best look at a junk yard[/b]
Front 1ine, If your talking about the plastic one, its not hard but it may take a day. You will have to be very delicate if your using a dremel, you dont want to punch through. I will am going to take it easy with my old one on the porting.How hard will it be to do this? Also, how long will it take you think?[/b]
DJQuick1, 84FordMan, & MR Tea Just for clarification... What is the overall benifit to having a larger intake manifold on the V6? More power possible?[/b]
yes and the link will explain it better than I canPlenum Volume and Plenum(runner) Length is different, correct?[/b]
Yes.Is anyone still interested in this still.I have another company that is interested at tackling this project in the next few weeks.[/b]
Great Explanation D.
But i have a lil' question may be contridictive or stupid but. with porting......more rather port matching the Upper Intake manifold with the Lower and and actual head ports.........that doesnt increase actual runner length, correct? that icreases plenum volume, right?
if this is the case. the porting shouldnt change the Powerband, it should just in theory and hopes increase the power and torque availible in the same powerband, Correct?
Now, if we were to add a plenum spacer-
IE- the spacer used in the 350z's...........now that would create the effect of longer runners and incorporate the change in powerband you just explained, Correct?
so my general conclusion is that doing a simple Port match will only give more where we already have, not change where we have it?
am i correct in my thinking.........of course there is more to it than that, but simply in this, would i be correct in my thinking?
I am definately interested!Is anyone still interested in this still.I have another company that is interested at tackling this project in the next few weeks.[/b]
Yes, they are different, but the longer the plenum length, the greater the volume. (if the tube size stays the same....) There is a huge amount of engineering that goes into the intake to get the most HP/TQ from the engine at a given fuel consumption. The actual cost of making the part is probably about $50. The cost of making the part wrong is $millions$ lost in the market because your engine is underpowered or gets crappy mileage. (or bothPlenum Volume and Plenum(runner) Length is different, correct?[/b]
