Hey guys,
First post here, and in need of some help.
Firstly the engine warning light has come on, and had it checked out, and it came back as the EGR valve was at fault. I have read up on this, and I'm pretty confident on what needs to be done.
I'm pretty sure the EGR valve is located at the rear of the engine, above the inlet manifold. Does anyone have a photo of it shown in the engine bay?
Secondly, the oil pressure warning light is blinking on every now and then. It generally comes when the engine is cold (it's been below zero here). Sometimes is comes on on idle, other times when the revs drop to around 800 rpm, but once the engine is up to temp, the light never comes on. This seems backwards to me, as the pressure should drop when the engine is warm and the oil is thinner, not the other way around.
The engine is fully topped up. I'm going to do an oil and filter change anyway as it's been around 6 months since it was serviced, but I'm unsure as what oil to use. Halfords say 5w30, which to me doesn't seem quite right. The car is a 2004 2.0 TS with 110k miles.
Any advice much appreciated!
Deano
Deano
