how would i pull the radiator. Is it capable of being pulled from the top of the engine compartment or does it need to be pulled from the bottom. the main problem i see is that if jacked up with a home jack that the center jack mount would cause a clearance issue with pulling it from the bottom but the black piece that spans across and connects to the top of the radiator bracket is causing me issues with being removed.
any help would be much appreciated. thanks.
Hitting a coyote at 90 causes problems... fyi
