Just wondering, if anyone had the technicals on how to properly do a heel and toe?
Any help is appreciated.. thanks a bunch in advance.
Heel toe shifting is when you come into a turn braking, downshifting, and giving gas all at the same time to match the rpms so that you can come out of the turn going as fast as possible in the shortest amount of time. Generally, it works better on cars that have the proper sport gas pedal (looks like it's coming out of the floor and is long and goes straight up as opposed to the 6's which comes from above your toe and is a small pedal). However, that being said it can still be done, but not easily. When braking into a turn, downshift with your left foot on the clutch as usual and your right on the brake.Originally posted by DragAzn@Jun 19 2005, 11:45 PM
[snapback]434604[/snapback]
I probably get into a wreck if I try this.Originally posted by Justbringit41@Jun 26 2005, 05:54 PM
Next you need to keep your TOE on the brake and swing your heel (yes heel) over to the gas and blip the throttle so the rpms match and you get a smooth downshift as opposed to a rough bumpy one. You'll see what I mean when I say the 6's gas pedal is not meant for heel toe shifting.
[snapback]440373[/snapback]
