Hi Guys,
I have a 2005 Mazda 6 TS2 143hp diesel that has developed an issue.
The engine will not rev above 2000-3000rpm in any gear. When it reaches said revs, it drops to idle again. If you sit in neutral with your foot on the accelerator the engine just cycles (Revving to 2000rpm and then back to idle and so on)
I can easily take the car to 70 providing I change gear before 2000rpm.
I have attached my scanner to the car which has revealed no fault codes. I have no lights on the dash either.
I have tried cleaning the MAF with carb cleaner to no avail.
Just to mention this car has had the Cat and DPF removed by previous owners.
Thanks,
Pete
Thanks,
Pete
