I'm about to install an amp and I've been looking through all the older threads for some help...I'm wondering if anyone has drilled a hole in their 6's firewall to run a cable to the battery? I see from another thread that diesel5599 ran his cable between the main harness' grommet and the firewall, then sealing it to prevent leaks. Entropism wrote that it's best to drill a dedicated hole with a grommet to avoid rubbing through the insulation... I tend to agree with Entropism, but I'm a liitle hesitant to drill a hole in the firewall.
Has anyone found any other (easier) ways to route a power cable into the engine compartment? Or if you've drilled a hole, where did you put it?
