1 - 18 of 18 Posts
Hi everyone
I have noticed a fairly steady drip after a hot day from mid of car (attached photo).
Tested the puddle with a tissue and the colour was light yellow, with a thin texture and not really any smell. Didnt seem like oil.
Took into my local garage and they tested aircon and found leak repeated. They are suggesting that Japanese cars dripping a coloured liquid like this is normal? Does anyone know if this is correct?
I would understand clear water condensate from air con being normal, but a coloured liquid? How would this clear liquid become any other colour without a coolant leak?
Thanks to all replies in advance!!
Alex.
Hood Automotive tire Road surface Asphalt Tar
Road surface Wood Asphalt Grey Tar
Administrator
"They are suggesting that Japanese cars dripping a coloured liquid like this is normal " - Lol, no. I've not once heard of anyone on here leaking a yellow fluid and I've been around almost 5 days a week for 11 years.
"Didnt seem like oil" - Are you certain it's not though? Did you get under the car and see where it's coming from? I've seen cars that had a super small oil leak because of an oil pan washer not behaving and it "appeared" like water on the ground. From the image, that leak is defnitely coming from the area of your pan, and if someone didn't replace the 1-time-use aluminum washer when changing the oil, it can definitely leak.
Administrator
2021 Mazda6 Carbon Edition
No. It's NEVER "normal" for fluids (other than water from A/C use) to be dripping from any vehicle, Japanese or otherwise.
I'd take it to a more-respectable garage if you do fear there is a leak.
Reactions: Byakuya
I have had a pressure sensor changed a couple of months back, maybe small leak local to that area + condensation from air con? They suggested that all liquids were at correct level on check though. Also mechs said that raising the car and putting aircon onto full blast for a while.
resulted in a similar leak, I'm hoping that if it was oil leaking they would have been able to tell...
Had to have and injector seal replaced a year ago or so as diesel began to leak into engine oil, hope I'm not seeing something similar to keep engine oil at normal level while its actually leaking 😃
Any idea of mazda 6 aircon condensation usually drips out in this area also?
Again thank you for the reply.
What colour is your coolant, is that going down?
The other liquid that is yellowy is brake / clutch fluid but that amount you would have no brakes and as you say it doesn't feel like oil. Hydraulic fluid smells a bit like cats urine.
Is it possible to run a day without AC to eliminate that?
What colour is your engine oil on the dipstick, if blackthen it cannot be sump oil. Manual gear box oil, but that tends to be brownish and if you have a drip that would be very unusual.
If its water based then it would tend to evaporate or drain away, but oil would leave a stain. Try a piece of cardboard weighted down in the right place or even a plastic tray to catch some.
A decent mechanic if he puts it on the lift when its hot and removes a couple of the small access panels should be able to suss it.
Japanese cars are no more susceptible to leaks (in fact probably less so) than any other country make.
Good luck and let the forum know the outcome.
Agree, catch it in a clean container, like a disposable aluminum baking pan or a washed out metal can. Then see if it is clear or not. You are probably picking up discoloration from the pavement that the AC water is dripping on.
Coolant in these is green (if FL-22, and it should be) and all glycol-based coolants feel slippery between the fingers. If its not then it isn't coolant. That's not likely oil. The bad news is it could be the A/C refrigerant oil, which typically is clear when it goes in but who knows after a while, and if it is then its leaking into the condensate pan which means the dash gets to come out to replace it -- and that's a five-alarm pain in the butt.
You'll know if the A/C stops working, obviously....
There is very little oil in the refrigeration system, if this leaking has happened a few times that the ac compressor would have seized up by now.
You wouldn't have to touch the dash, as I cannot see how the evaporator could leak without human intervention, condenser yes, by a stone through the grill ot malicous damage. It wouldn't take long for the ac to show its not working if its hot. If you had a refrigerant leak you wouldn't be getting any condensate.
Could it be washer fluid running out the heater drains after its been used just before stopping.
Coolant, granted is Fl-22, but has some body put something else in.
If its oil you can tell by rubbing between your fingers and it wouldn't mix well with water.
Interesting.
Lets hope its something not expensive.
Rusty water can appear yellowy.
Thats from the condenser, but not limited to Jap cars unlike that idiot suggests. It can get colored from rust or body paint.
You did say the puddle was under the middle of the car, there's nothing back there to leak
There literally is...
What leaks in the center/middle of the car? Serious question.
Not sure how i can be more clear...i never said the SOURCE was in the middle of the car, water flows where ever the eff it wants to and comes out in really odd places.
I would aggree there, bit like vibration also, not always where it is coming from.
The condenser is in front of the radiator but the evaporator is behind the dash which cools the air condensing the moisture which leaks out the plenum drain. I have yet to locate this.
I was told by the dealer could be by the right hand side sill area and may leak onto the undertrays so it may actually comes out further aft depending on the gradient of the road, hence middle of the car so to speak.
If the various fluid levels are not going down, ie radiator, oil level, hydraulics, then it is probably coming from the ac, which at this time of the year is quite normal.
Has the underside of the car been checked at the end of other journeys and parking places. If you park on clean concrete rather than tarmac you may be able to determine what the liquid is better or park the car in your garage, put some sort of a tray underneath where you think its coming from and check 30 - 60 minutes later.
Compressor, condenser,( liquid) expansion valve (usually a small capiliary/oriface rather than a valve) evaporator next to the heater core, (gas) then the gas goes into the compressor.
1 - 18 of 18 Posts
