Would these fit?
1080 Views 15 Replies 6 Participants Last post by  afnan_jamil
Guys... I need your opinion and advice... would these fit on my car? If so, how would the look?
Thanks!
http://www.buywheelstoday.com/products/?id=2831
1 - 16 of 16 Posts
with a hell of a fender roll, maybe
Maybe, with a hell of a fender roll. A little to close to call, I wouldn't risk it personnally.
How come? Our stock 17's width is 7 inches too? right? So, why woudn't they?
Stock offset is +60. The best you can do with the ones you linked to is +40. That is the difference.
what does that mean? sorry, I don't know much about the wheels/tires...
It means that with the new wheel, even when you keep your stock tires, your wheel is sticking out 20 mm more than your stock wheel.
oh... so it would just stick out about 20mm right? Is that a big difference? would it hit the sidewalls? I mean the fender?
20 mm doesn't sound like a lot, but there isn't much extra room to begin with. You will have to roll the lip of the fender flat to keep the tires from rubbing on the fender. The size and type of tire will also influence how badly it will rub.
I encourage you to poke around the stickied threads in this sub forum. Most of the information you need is contained within.
Thanks Slv5sPitt. I didn't know it would make that big of a difference...
Is there any other sets of wheels that you would suggest? My price is about 120-130. I know it's not alot... but still, just wanted to know!
remember you get what you pay for. if you go with inexpensive wheels, there's probably a reason they're more expensive. you may get excellent wheels, or you could get softer alloys that bend easy. what you save now with less expensive wheels may be nothing compared to replacing rims and bubbled tires
It means that with the new wheel, even when you keep your stock tires, your wheel is sticking out 20 mm more than your stock wheel. [/b]
Might I suggest, if you really like these wheels, taking the advice of the website; to be exact
".....For expert fitment advice, please call us at 1-866-747-6247 ..."
you need wheels with a larger offset, maybe they might have them in a different fitment for your car.
I know you roll the dice when you buy "cheap" wheels, but I got a set of ADR Design wheels off of eBay for $410 shipped. They have held up well so far and that says a lot considering the roads in Pittsburgh suck. My opinion is that just because wheels cost a lot doesn't mean you won't have to replace them. More expensive wheels might not bend easily, but they sure get curb rash just as easily. They way I figure it, I can get 3 sets of wheels for the price of some others. In case you were interested, the seller on eBay was Nateswheels.
Thanks... I guess I'll just go to Discount Tires and see if they have any deals...
I know you roll the dice when you buy "cheap" wheels, but I got a set of ADR Design wheels off of eBay for $410 shippped. They have held up well so far and that says a lot considering the roads in Pittsburgh suck. My opinion is that just because wheels cost a lot doesn't mean you won't have to replace them. More expensive wheels might not bend easily, but they sure get curb rash just as easily. They way I figure it, I can get 3 sets of wheels for the price of some others. In case you were interested, the seller on eBay was Nateswheels.
which ones did you get?
I picked up a set of the ADR Design Competiton 7 in 17x7 with an offset of +48.
1 - 16 of 16 Posts
