1 - 20 of 39 Posts
Trying to find tires locally, and discount tire has some Michelin Pilot Alpin PA2, in a 235/45R17 size on these rims
are they going to be too wide for the speed6?
It doesn't say the offset. If it's got a -45 to -55 offset, it will fit.
so the tire itself won't be too wide?
called back - he said the offset was 42 mm..... still ok?
Oh sorry. Get a 225/47
the 235/45R17 came up in their computer, and they don't have the 215/50R17's that i've seen recommended...
YOu can use a 225/45/17
Discussion Starter · #7 ·
So 225/45's would be better than 235/45's?
Might have rubbing with 235's if offset is lower than -55
Discussion Starter · #9 ·
That's what's got me worried... they said the offset was 42mm... and looking at the calc here:
http://www.wheelsmaster.com/rt_specs.jsp
it seems that the 235/45 will stick out 18mm more (based on 7" wide rims both and 50mm stock/42mm snow offsets).
I think I'll call back and see if they have the 225's
I was told that 18mm more on the outside will rub. Also, 235's on 17x7 rims will be a lot of pressure on the sidewalls in.
Discussion Starter · #11 ·
callec back, they've got the 225/45's and will do them for the same price...
wheel calc says they will stick out 13mm...
More than I want to spend but I guess I waited too long to get a good deal...
and why ooh why no 17" steelies?
offset is only -42? you might have issues.
Discussion Starter · #13 ·
See, you are right between the two.
Discussion Starter · #18 ·
Do you know where to get them?
Discussion Starter · #20 ·
1 - 20 of 39 Posts
