Help? Really confused as to what the lowest offset I can use.
The lowest offset you can use depends on the tire size you plan to run, and whether you plan to modify the fenders.
There are no guarantees without checking fitment on your specific car, as manufacturing variances can slightly change the fender to tire clearance on each vehicle. With the +40mm offset listed, I would guess you will probably need to roll the fenders (unless you are going to use some ridiculously skinny tires).
Hi jd, thanks for the response.
Let's say I want to run the stock 215/50/17 size, without rolling my fenders, would I need +45 offset?
Thanks
