Yeah I got hayden one from "poser"boys and it was rated motor home use LOL! My tranny still works after like almost 2 years of usage so I guess it worksI got the big mutha' shut yo mouth from Napa, works good lasts long time, but the one most everyone get is the HR (i think) and it work good last long time AND comes with mounting brackets, whereas the Napa one I had to frabricate custom zip-tie mounting brackets. [/b]
I ghetto fabbed/Hill Billy Rigged my own brackets from home deopt. If you find crossbows how to pictures it's exactly like that. I put insulation around the line where it would possibly rub mettal or sharp edges.Cool.
I looked into it and called around to few auto places here. Most of them didn't know what tranny cooler would fit with my car. Some even told me they 'don't make them yet'.
It's an 06' 4cyl.
Did the B&M have mounting brackets included, or did you have to fab something? [/b]
Same one i bought. Pretty easy install per instructions from this forum, and bought extra hose from Pepboys.I purchased the B&M Racing 70264 BMRacing.com.
I bought it from SummitRacing.com. It came in a kit with mounting brackets and some hose (althought I needed more for the install).
+1 karmaI occasionally check the bolts and hoses to make sure there tight.
I havn't found anywhere that has these, or where I can order it from.Also install a MagnaFine Transmission Filter at the same time. It takes less then 5minutes from added protection cost is $20 shipped.
3/8 should work, sometimes even better, 11/32 can be a pain to get over the barbs. Just use hose clamps and you shouldn't have any problems.They didn't have 11/32 when I went
The guy gave me 3/8 (1/32 bigger). The barb seems to go in easy enough, and looks like it won't leak, but I'm not sure.
Has anyone tried 3/8, or does anyone know of a good way to test it?
I don't know what kind of pressure is going to be flowing through it.
Any ideas ??
Someone posted on it a little ways down the page, but the link they posted won't ship to Canada
I have a friend in the states that could probably help me out, but I'd rather find someone that will ship directly to Canada.
Thanks man for the info, i think im going to attempt the install maybe today or tomorrow depending on the wheather. Ive read the posts on mazda6tech.com and it doesnt seem difficult, so im not too worried. Ill post again when i get it installed. Thanks again for the info.All the information here is already posted elsewhere, but to sum it all up. Dont be intimidated by the install its all easy, you could do the Tb bypass as well at the same time (have some spare Coolant near by) 3/8 is fine, just check up on your clamps to ensure your holding the pressure. you can buy the filter here: http://www.emergingent.com/magnefine/order_page.htm you do not need the 3/8 connector thingie, thats for putting the filter on metal lines. a total of 8ft of hose is plenty, i threw away the hose that comes the kit, and bough some better 11/32 hose from pep boys for $12 per 4 1/2 ft. As for mounting, go to the link on Maza6tech.com for installing the 6cyl cooler, dont use all the zip tie things. otherwise just follow everything in the 4cy page (if you have a 4cy that is). the part 70264 is 14,400 BTU/24,000 GVW, thats cold, probably to cold for some climates, but if you run hard on your tranny, then its good. Good luck with it all, well worth it.
SLCATENZA
