1 - 16 of 16 Posts
Down near the ac compressor.
OK, I think I see it... it's above the oil filter, right? Next question, how am I supposed to get at that? Do I need to take the filter out? Can I get away without draining the oil to replace the switch?
What year do you have? You should be able to get a socket on it after pulling the plug off. I do't believe you will need to drain the oil.
it's a 2004. It's impossible to get my hand in from the top and I can just barely reach it from the bottom
Are you sure it is bad?
Had a mechanic tell me it was bad. Was going to do it myself but then it looked like so much work to get at it that I ended up paying to have it done. Had a pressure test done at the same time and pressure reads OK.
I've added a tee fitting and capillary tube to a mechanical gauge - and I've deleted my AC, but that is the stock switch & connector treaded into the tee and the tee is threaded into the original hole.
Good luck.
CR
Hi ToeCheese,
How much did the mechanic quote you for the labor and parts? The oil pressure sender also went out on my 2004 Sportwagon. Pressure check OK but oil pressure light on. Mine said 3 hours...
Thanks,
Shawn
By chance, can I get confirmation whether or not any oil needs to be drained in order to change out the oil pressure switch?
Planning on changing out this weekend on my 05 3.0L V6.
Yeah, I know this is an old thread.
You don't have to drain anything. Just wait for it to cool.
That's what I want to know how in the world are you supposed to get to the thing
1 - 16 of 16 Posts
