I try to install my HID 3 month ago
after i install it , i try to turn it on, it only work for only 10 sec,and then turn off
So i change back to my old light bulb, it not working too
i think my headlight fuse is burn
so where is the headlight fuse, how can i remove it ??
is there 1 fuse for both side or they have 1 fuse for each side???
Do i need to get a higher Volt fuse ?
The fuses are in the engine bay in the fuse box, which is on the right hand side of the engine bay when you are looking in to it. You should not, however, need a higher rated fuse to run HIDs. Make sure you don't have some wires crossed somewhere.
so many fuse there
which one is it?
