I ask because if they HID goes off, flashing other drivers with high-beams would reduce the life of your HID bulbs, right?
HID's stay on when the highbeams go on *Edit*: on the speed6
if you have your hid's in your lows, then flashing your "halogen" high beams wont cause the hids to turn off...they stay on constant......your fogs are a ddiiferent case tho, they will turn off once the highs are on, and if you have your hid's in your fogs then you may want to re-wire them so they dont do this, otherwise it will kill your ballast.
