Hi
I have a mazda 6 2011 with 16inch wheels.
The rims are getting a bit worn not bad. So can either get refurbished or new ones (used and new to expensive)
Any advice?
Can I get a different design than original ones as can only find same design?
Yea, you can use wheels from just about any other Mazda that has the 5 bolt pattern. You might need new tires depending on which ones you want, not sure theres much of an option in the 16" range unless they are from a 3 or other model.
Thanks for your reply - I still haven't sorted this yet hence the late reply. Can I use any other car manufacturer alloys other than Mzda?
It depends on if its the right bolt pattern and backspacing. Theres not really a repository of wheels like that to cross reference.
Thanks do you this the ones attached would work
Thanks do you think the ones attached will be ok?
