I noticed the other day when I take my 03 6i into a hard right turn or a turn in a parking lost, there is a high pitch squeal from the front drivers side wheel... Is this what I think it is? If so, I believe it's covered under warrenty, right?
When a wheel bearing is shot it will make a grinding sound that usually can be felt as well as heard. The high pitched sound you're describing sounds like it might be you brakes. Maybe a wear indicator on the brake pads?
If the problem is a wheel bearing, yes it should be covered under warranty.
There's a TSB out for it. It's a problem with the brakes. Search for brake squeal and you should find about a 100 posts about it. Wheel bearings tend to tick when going in a straight line, they don't squeal.
