1 - 8 of 8 Posts
Hi I am thinking to buy an OZ Antares Wheels.
The prices here (Panamà, America Central) are:
225/25 R17 with PROXES T1S $$. 1,460 included installation
and the
234/40 R18 with PROXES T1A $$. 1,900 included installation
I had the Sedan 2.0 with 133hp Automatic STRATO BLUE with 205/55 /R16
What size do you recomend me?
I will like to maintain a similar acceleration...
If I buy a R17 I can low the suspension to fill some space in case that I decide for the R17
Thanks
TOMAS
Reading Topic: Wheel 17 or 18
I think u will be better off with the 17s, cause 18s will put a lot rotational weight on ur car. Heavy wheels can cause major decrease in acceleration. If you really want 18s i recommend you to find the lighter rims like rota attacks or more expensive volk/ray wheels.
Or just look for any place that sells forged wheels. I saw a place that had 13 lb 18" rims. That's like half the weight of stock. Be ready to pay for wheels that light, though.
What do you think about the OZ Superleggera 17x7 w/45mm offset and 15,2 lbs or the 17x8 w/48mm 15,4 LBS
Thanks in advanced.
TOMAS
Replying to Topic 'Wheel 17 or 18'
Also keep in mind with a bigger wheel, you'll need a thinner tire..... if your roads are anything like they are here in NC, a pothole will feel like you dropped an axle.
i wont put any lower profile than the stock ones on my 6 since the roads are way too bumpy here and there are as many potholes as on the moon so...
Thank for your Helps
You right.
The roads in Panama are not good, too many holes. I know how is sound the wheel in a pothole, very metalic, jeje.
I think that i am going for the 17x 225/457 offset 45 with Touo Proxes T1S. According my measures the clearance inside +10mm and outside +10mm
Regrads
TOMAS
Will 18x7.5 +43 offset fit the M6?? I'm thinking about getting the 5Zigen MK-6 hyper black..let me know if that will fit perfect and I'm also going to lower it with Eibach spring.
1 - 8 of 8 Posts
