I was curious if anyone would have a solution for my problem.
The car: 2005 Mazda 6s w/ sunroof
When it rains, the carpet on the driver's side of the car gets quite wet, and I cannot seem to figure out where the water is coming from.
From my searching on forums, I have tested the following items:
1. Poured water down sunroof drain, water drained from just behind driver's wheel.
2. Checked door drains, and water can drain out the bottom of the door.
3. Tested windshield drains. Most water drained from the same place as the sunroof, however, I did notice that some water did drain from a little higher (coming over the fender liner it looked like). Is this normal?
Has anyone had similar experiences as this? Any possible solutions would be appreciated.
Thank You
Chuck
Thank You
Chuck
