1 - 3 of 3 Posts
Hi all,
Anyone encountered a model with this shift lever?
Am having trouble removing the shift knob even after 2 screws removed and applying slight tugging force upward to the knob. Wouldn't wanna damage anything. Lower button is an Overdrive button.
you can't actually remove the gear knob, there's actually a surround around the gear stick that will unclip from the rear and sides of the console trim. View attachment 237920
you can't actually remove the gear knob, you have to unclip the surround around the gear stick.
Clips are located at the rear and side of the centre trim
237921
1 - 3 of 3 Posts
