1 - 15 of 15 Posts
I installed my WeaponX coils this afternoon and I have to say that first impressions are very good.
It definitely starts a bit sharper and idles smoother. Off-idle to low speed, you don't feel like someone slipped a supercharger under the hood, it simply feels a bit stronger and smoother. However, under heavier throttle I am absolutely pulling much stronger. But again, more smoothly as well. The engine feels like it has more of a sweet spot, and the throttle response is better.
I have the Blizzaks on due to today's weather, so I can't compare if my cruising RPMs have changed like others have reported.
There is one thing that has me a bit perplexed... Some of the raspiness is gone from the exhaust. My car has never had a fart-can sound, but there was definitely a buzz when approaching 3500 to 4000. Most of that buzz is gone and the exhaust is fuller and deeper in tone. Same goes for revving when in park. Whatever it is, I'm good with.
I topped-off the tank so I can start getting a few of those going to see how MPG might change.
Very happy with the $ spent and apparent benefits. And like the headers, if it prevents problems from a common V6 issue down the road, even better.
A couple of things not in the instructions, but I'll recommend doing anyway:
-They don't say to do so, but I put a dab of dielectric grease inside each tip and boot on install. I also put a very, very light film on each cylinder seal before sliding it down into the opening. Should help seal the chamber as well as keep the seal from sticking.
-The instructions stress how difficult it will be to 'snap' the coils down onto the plug. What I did was use a dual-face hammer and tapped each coil lightly two or three times with the soft-face. There was a definite difference in how secure the plug felt afterward. The nice thing about the hammer is you're hitting the rim of the coil body and not the section over the electronics.
Day Two:
There is more power. I'm not ignoring what is an obvious improvement in throttle response, but there is additional power down low as well.
The change in exhaust tone is odd. Cruising at 70 on the highway the car is noticeably quieter. Even some of the off-idle burble is gone. And that's fine with me. Last thing I want my car to sound like is someone who thinks his V6 Mazda is a V8 Mustang.
---edit---
They cost me $329 plus shipping.
http://www.weaponxperformance.com/catalogv137/index.php?main_page=index&cPath=37&sort=20a&page=2
Discussion Starter · #2 · (Edited)
We have nothing on emissions at present, and thankfully nothing on the horizon. If we do, I'll hope for no visual..... With the MagnaFlow cat, I'm sure I'd pass the sniffer.
Good point on the signature - thanks.
Nice to hear that you're having a good experience with the WX coils. I've heard and seen too many people having issues with them,which is the only reason I didn't jump on them.
Looking forward to hearing more about your experiences with these further down the road.
----edit----
I just Google'd. Yah, seems like problems here and there. Most of them seem to be older issues in 2009. I'll just have to see how it goes.
I noticed you said common problems about the headers? Just curious what goes wrong with them/when if you know? Also did you use the rubber side of the dual faced hammer? I'm about to install these this summer which is why I ask.
Discussion Starter · #6 ·
The V6s have a nasty habit of the pre-cats breaking-down and pieces being ingested back into the cylinders during deceleration. Obviously converter 'dust' and chunks isn't good for the engine and it goes bye-bye.
And some seem to experience their pre-cats melting into a lump, turning into a red ball, choking the engine, and also killing it.
I decided about 14 months ago to avoid either situation and go with MSDS headers and a MagnaFlow cat.
And yes, the soft rubber side. Just 2-3 soft taps.
Hmm interesting, maybe I'll have to invest in some headers then, thanks for the info, can't wait to install those WeaponX coils. Just curious did you go with the stock spark plugs or decide to switch over to something else like ngk iridiums or something?
Discussion Starter · #8 ·
I just put-in NGK G-power about 4 months ago, so I stayed with them.
Aside from longer-life between changes, not much to justify the cost of iridium over 'regular' plugs: Sparkplugs.com - Spark Plug 411
Apparently the stock coils put out 20K volts.
I just ordered some ACCEL 4V mustang coils for my 2006 Mazda 6 3.0 ltr.
They are 40K volts. Hopefully have them on later on this weekish.
These Accel ignition coils feature advanced bobbin technology, highly specialized silicone magnetic steel cores, along with optimized winding, resistance and turns ratios to delivery 10-15% more energy than the OEM Ford coils. Specialized high temperature epoxy resists shock and vibration, while increasing thermal conductivity. Accel Super Coils feature bodies, brackets and towers molded in ACCEL yellow and feature brass secondary contacts.
$40 ea Canadian.
So... how are the Accels doing? Any noticeable gains?
Got pics?
Discussion Starter · #11 ·
They are 40K volts. n.
That doesn't mean shit. Utilization of voltage is not dependent on availability of voltage.
It's the logic/electronics of a coil that determine it's benefit. Picking a coil by voltage is like picking a tire by how black it is.
Discussion Starter · #12 ·
I guess you didn't read the rest on a previous post maybe:
it's a Mustang coil only 10-15% better.
Why did you buy your coils?
I have deleted all my posts, this one later, but the above was there, maybe off topic.
Did you see me quote that stuff? Did you see me comment on that stuff? No, you didn't. You make a statement regarding voltage output. And what I am telling you is that you might as well have said "I had roast beef for lunch today". Both statements have the same non-guarantee of coil performance or effect on HP or torque.
I guess you didn't read what I quoted and responded on.
Discussion Starter · #14 · (Edited)
--Dave had messeged me as well, and part of what I responded was on the grounds straps I added, which WeaponX recommends---
On interference, I've had no such problem. However, WeaponX does recommend adding a ground strap or two.
I added one from the passenger's side motor mount to the chassis, just below the ABS module. It is a 12", 14ga battery cable with terminals at each end.
I also added a lightweight one from the TB to the negative terminal. I don't know that I've ever believed in grounding the TB, but for $3-4, I figured why not and added one at the same time.
There is also another 16", 14ga battery cable from the block to the chassis, pretty-much under the battery.
I confess, I have no hold-downs at the time. I need to pick-up a piece of angle or straight project steel and make some. I've been hoping to find some pre-existing 'slick' brackets to-do so, but I think I have to admit I'm not going to find any.
----re-do attempt on pics----
Reactions: dawei213
1 - 15 of 15 Posts
