1 - 3 of 3 Posts
ok there are a few things that I need worked on, and want to know what will be covered under the warranty and what won't be. I need my headlights adjusted (but have aftermarket HID's), I need to get my heater fixed because it only works when accelerating, I need to fix a slow coolant leak which could be from a leaky head gasket or a number of other things, my transmission, when cold, has a heinous shift from 1st to 2nd (reflash TCM, and flush ATX fluid?), and lastly I have a brake pedal that squeaks that for the love of me I can't fix my self. Any help/info is greatly appreciated!
Thanks,
Alex
Administrator
2018 Mazda6 GT Reserve
I believe that everything that you mentioned (minus the headlight adjustments) should be covered under warranty. Since the headlights are aftermarket, they may shy away from those. There are instructions for adjusting the headlights yourself, located somewhere in the forum...
Reactions: Halozander
1 - 3 of 3 Posts
