I need to get this off my chest, plus maybe someone will have a suggestion that can help me.
I have a 2006 MS6 with extended warranty... A month ago I noticed my gas mileage tank from avg 21-22mpg to 16-17mpg. One day after getting out of the car I smelled a strong oil smell from the bottom of the car. I took it to a local place (the Mazda dealership is like 30min away and I was wanting to get a quote for diff fluid change). They put it up on the rack and found that all the fluid had dripped out of the rear Diff due to a seal problem.
I took the car into Mazda and they sealed it back up and filled it up with fluid. I figure that the rear end most likely ran dry/semi dry for over 300 miles and asked if they were going to replace the bearings in the rear end, they said "nope".
I've driven the car through a few tanks of gas now and I'm only getting 16-17mpg no matter how I drive, even when I put the economy map on the car I still only got 17.5mpg with lots of FWY driving. There is clearly still an issue, so I took the car into Mazda again today. They ran every diagnostic on the car and came up with nothing. The drop in MPG started with the rear end loosing fluid and they refuse to do anything more than they already have without definite proof that there is something wrong like a car code or something breaking.
The service rep told me to call MEPP (mazda extended protection program?) and talk to them about it. They simply stated that they can't do anything and it's up to the dealerships to find what's wrong and fix it.
It seems like MPG is getting slightly worse over time (over the past 4 Tanks). I'd really not get stranded out if the rear diff finally decides to grenade, but at least then they'd have to do something about it.
I've been around auto racing all my life and have always known that if a "wet" bearing is ever run "dry" you need to replace it, even if it appears to be okay... I asked the service rep "what happens if my MPG drops by 50% overall" he replied "bring it in and well look at it"... I then said noted that he said they can't do anything unless something appears broken or the cpu tosses a code and he said "that's correct".
So it looks like I'm suck with a car that is getting worse and worse MPG as gas is about to hit $4gal here in CA, costing me money, and worried that the rear end could possibly grenade at any time. I'm not happy about this, and I purchased the extended warranty so that I wouldn't have to lay out $ to get drive-train shit fixed!
Anyone have any ideas, Mazda people I could call, ect?
Meanwhile I may be forced to drop the MS6 and get something else... I'd rather not, being here in CA all cars have a 9.75% Sales tax and insurance is fricken expensive in Los Angeles, except the MS6 seems to be the same as a normal mazda 6 4door, so it's cheap..
Thanks for any info and for reading my rant,:huh:
