Over the years, I have seen many questions come up about whether Altima wheels or Honda wheels will fit the 6. Fitting original equipment wheels from another vehicle manufacturer poses problems not usually associated with aftermarket wheels. Original equipment wheels are bored out to exactly the size of the hub diameter of the intended application. For example, the Mazda6 has a hub diameter of 67.1mm and the center bore of any Mazda6 original equipment wheel is 67.1mm. Some Toyotas have a center bore of 60.1mm. So, while the bolt pattern may be the same, and the offset is good for the 6, the wheel won't fit over the hub because the opening is too small. The question is, where do you go to find that information on other vehicle's center bores and bolt patterns?
I have finally come across a website that provides that information. It is by no means complete, but it contains a lot of vehicles. Please reference this link if you are considering buying original equipment wheels from another vehicle manufacturer. Enjoy.
http://www.discountedwheelwarehouse.com/Ve...n_Reference.cfm
