Can I use these stock tires in the rain. I live in the Bay Area, so no snow but periods of moderate/heavy rain. It was light rain today and I felt no trouble but wondering if anyone can provide any insight on these tires.
Bridgestone Potenza RE050
Yes. Of course. You have summer performance tires, not racing slicks.
Any tire that has a "tread," that is, open grooves can be used in the rain. How effective a tire is in the rain will be a function of the tread/void ratio and the depth of the tread. That is the tread block to groove ratio.
As was mentioned, they just can't be used in very cold and such (which should not affect you). The stock tires on the MS6 are awesome in rain.
Actually, it is hard to think of any tire that would be better in the rain.
There are two separate qualities you want for a rain tire: a tread compound designed for high friction on wet pavement, and a tread design that allows the tire to maintain contact with the pavement. If the water cannot be moved -- that is, merely wet pavement with no free-to-move water on it -- then tread design is unimportant; but if there is standing or flowing water, tread design is important. The nature of the tread compound is always important.
The Potenza RE050 has a high void-to-tread area and a directional tread design, which makes it well-suited to the front position where measures against hydroplaning are mainly useful. (The rear tires mainly run in the track of the front tires about a tenth of a second, at highway speeds, after the front tires, if they have done their job, will have cleared the path for them.) As a summer tire, the RE050's tread compound is chemically designed to repel water; as a "performance" summer tire, the tread compound is relatively soft and sticky at above-freezing temperatures; together, those two qualities give the best traction one can hope for on wet pavement.
