1 - 2 of 2 Posts
Hi Donny, would you think we could get some upgraded rear sway bar bushings for the MS6? I'm thinking some of us may not want to go to the trouble of swapping out the rear bar, but wouldn't mind a bit of improvement in rear roll stiffness and responsiveness. Apparently regular Mazda6 swaybar bushings are really soft rubber, allowing the bar to bend a bit instead of twisting fully. If the MS6 rear bushings are made of the same rubber then changing out just the rear bushings would provide a bit of increase in rear roll stiffness which may be enough for some of us. It would be a relatively easy swap, compared to changing the whole bar, and reasonably inexpensive.
This would give people a progressive path to increasing roll stiffness. They could try just the bushings and if they decide they need more roll stiffenss they can go to an aftermarket bar like the Whiteline without spending a lot of money.
What do you think?
1 - 2 of 2 Posts
