1 - 3 of 3 Posts
Hi,
I have a 2011 Mazda 6 110000km.
I was working abroad for a month last winter and when I came back the left rear brake was basically stuck. This wore out the brake pads and I ended up changing rear pads, discs and left caliper.
I was using the car for almost 6 months without any issue and it was now time for the annual inspection. It failed because of brake effect on right side was too low.
Naturally I thought the right caliper might gone bad during the winter as well so I changed it(including gliding bolts and new lubrication) . When I had the car inspected today it failed again. Same issue.
Is it possible that Mazda 6 have a brake regulator and it's gone bad or do you guys have any other ideas?
1 - 3 of 3 Posts
