1 - 9 of 9 Posts
Discount power parts.com has a pre-order for the turbo xs bov adapter to work with their RFL BOV and regular Bov... Price for the adapter is 39... just thought i'd throw it out there if u haven't seen it
Should be mid to end of this week accourding to TXS. I can call tomorow and verify (Monday).
Still waiting for block-off plates for the valve, no estimate on ETA as of now, maybe tomorow we will know more.
Just talked to Jermaine real quick, no word yet on the block off plates that are holding the deal up. Next week we hope!
For a recirc valve, Turbo XS has the RBV-H blow off valve.
Racing Bypass Valve -Type H Reversible (RBV-H) US$189.00
Identical in design to our RBV-H34 with the exception that the outlet of the valve is our standard Type H female inlet instead of a 34mm hose adapter. This allows the valve to be used either in normal fashion or "reversed". Using the valve in the reversed orientation ensure that the valve will only open up under vacuum. This is perfect for your drag racing car running 35+ psi.
1 - 9 of 9 Posts
