1 - 3 of 3 Posts
I've just became an owner of a 2009 Mazda 6 Ts2 D and it seems to be having some issues with the Turbo, it's making a grinding noise when the engine is idle, only way to describe it is sounds like a power drill powering down and running dry. I had someone look at it and they established the turbo is the issue, I just wanted to check if the turbo on the vehicle is programmed to the vehicle meaning it cannot be replaced or it is not so a replacement is possible.
You could do a direct swap.
Nothing else necessary. Just make sure it's the same turbo model housing you are using.
Sorry for the crummy news. Factory turbos should be quiet while idling.
Thank you, I managed to source a reconditioned one so will hopefully get the in soon :)
1 - 3 of 3 Posts
