You can get one from here http://www.protegegarage.com/1545-product-1545.htmlDoes anybody know where I can get the exhaust manifold for the turbo I'm putting on my Mazda 6i
:huh:can I just purchase a mazda speed 6 turbo and bolt it on to my 2005 mazda 6 I
You don't need to route the the BPV/BOV back to the intake manifold. People typically do this on draw thru MAF setups where venting to atmosphere would cause a temporary rich condition after a shift because metered air is vented off and lost.
There are two ways to fix this:
1. Run a blow thru MAF setup and have the BOV/BPV plumbed prior to MAF so no metered air is lost. Blowthru setups are far more accurate in terms of air volume and air temperature metering accuracy on a boosted app. Some people go draw thru simply because they are in fear of saturating the MAF (flowing more than the MAF can meter). But blowthru is the best in terms of accuracy. There are also ways to keep the MAF from saturating and increasing range.
2. Tuning TIP-IN enrichment
If I were you I would not waste time on a K04 or the stock speed manifold. Get an aftermarket speed manifold with a T3 flange. Why? Because it opens up numerous turbo options. Just my educated opinion
If that IS a show stopper, has anyone ever added a port somehow to the regular intake manifold to function in this manner? Drilling and epoxying a port somehow to a composite/plastic manifold gives me the heebie jeebies. We've considered getting a couple of throttle body spacers, welding them together, drilling and welding a port there, but now we're moving things pretty far out of whack and are unsure if we'll run into other fitment problems at that point.
Appreciate any advice or thoughts,
G.
The speed6 intake manifold will not bolt up to your regular 2.3L...... If you really insist on running recirc for the BPV/BOV and/or draw thru MAF setup just route it back to the turbo inlet/intake between the compressor housing and MAF. Just be sure to have about 6" from the port and the MAF to help reduce or eliminate reverberations
Any questions or further help don't hesitate to hit me up here or on my tuning page in my Sig.
Also....what are your power goals? Built engine or keeping it stock?
Thanks fellas, I really appreciate the advice, thoughts and explanations. We decided to stick with the "stock" manifold and turbo because we're not looking to make anything more than 8psi. We've got a weak automatic transmission (evidently) and it's the stock engine, so there's no need for anything crazy or really, for much of an upgrade path from here. This is primarily a project to add a couple of horses to a fun daily driver and learn a bunch in the process. By using parts that come off the shelf we hope to keep the cost down, simplify the install and work with fairly well known items. Once we step off into the esoteric and custom everything, well, bring in the bobcat with the cubic yard of dollars - and we aren't playing that game just yet.Have you tuned draw through vs blow through on the stock ECU? I'd suggest actually doing it before recommending lol, I've done both setups.
Draw through absolutely requires it be routed back into the intake if you want stock like drivability. It will run rich / bog/ even stall at times on shifts if you don't, and especially if you go into boost then go out of gear and down to idle you'll stall.
and with blow through MAF placement, MAF housing size, etc all come into play, and it just won't run right in boost unless you're very, very meticulous with MAF placement, and how much straight section of piping there is before the maf. You'll get MAF range /performance CEL's and limp mode often. I know, I've done it on my personal car trying with a few different MAF housings on stock ECU. Draw through ended up being the easier, better performing option.
And with the MAF through as soon as you hit 4.9 volts on the MAF the ECU kills power and you limp until you shut it off and back on, which is much easier to do on blow-through.
Agreed the K04 isn't the nicest option, but it is cheap, and can flow more than enough for someone who doesn't have a built engine.
Also- the bov recirculates back into the intake after the MAF, not the intake manifold
I attached a picture, not the best since it's not a mazda, but it does have a MAF and recirculating BOV. see how the BOV has a pipe going from the BOV to the intake behind the MAF? just like that.
Plenty of non Cali mazda 6's had Denso ECU's lol they are just low emissions ECU.. uncluding the mazda 6 MZR-CD DieselMust get a lot of cali Mazda 6 cars then....because those are the only 2.3L Mazda 6's that came with Denso ECU's.
I don't have time to argue with you. OP, I'm around if you need me.
