Turbo for the 2.3 6i
107125 Views 163 Replies 64 Participants Last post by  RiveraJ
7
This will be an evolving thread, but should provide enough info that we won't have a new thread every other day asking the same questions. Please bare in mind that the info provided is based solely on my experience and opinion. Please take the info i have and use it as you will, discuss the project with your local shop/tuner/dad/brother and move forward from there. Anyone with more info please feel free to give input, but i will be cleaning this thread up as it goes, so please don't bitch.
Q: What are my options for turbo'ing my 6i?
A: The options vary currenlty. there are 5 standard answers, most can be googled for more info
1) ]HiBoost (out of business, but used kits floating around)
2) F2 (never officially release, check with GP-Werks for more info)
3) HASS (via turbokits.com) (not produced, but at least 2 kits floating around)
4) built using Mazdaspeed6 parts
5) depending on where you are, a TRUST (Greddy) kit is available, though tuning has yet to work in the states, as well as fitment issues with LHD models.
Q: Do I need to build the engine? what boost can i run "safely"?
A: The stock block has been pretty good on about 8psi on pump gas. Anything more than that the bottom end should be addressed. solid tuning and race fuel can up that #, but people have popped engines above 8psi.
Q: What about the tranny, i have an ____ (insert MTX or ATX)?
A: both tansmissions will be fine.
1- The stock MTX has a tendancy to sheer 3rd gear at times (no specific power level, just some last and others don't)
2- Both 4 & 5spd ATX trans also work, though it's recommend to run 6psi on these setups. also, an additional trans cooler is essential as well for the atx.
Q: Can i make my own, i found a good kit on ebay?
A: sure, have fun, don't cry when it doesn't work right and cost more in the long run!
Q: How much can i expect to pay?
A: Quick answer is have $5k ready to spend, or don't think about it. Now, it depends on the kit obviously. F2's stage1 will be the lowest price KIT, and HASS ranges up to $4300 i believe. You can make your own Mazdaspeed'ish setup, but it is not a kit, so prices will vary and you'll need to find your own tuning solution. The install is amazingly easy in these cars, the install would range in the 5-8 hour range if you are looking at a shop. Most KITS will come with a tune to get you started, though it's recommended to to dyno tune your specific car, which is roughly a 2 hour job, though doesn't really need to be done ASAP.
Q: What else do i need to buy?
A: If it's a true kit, then nothing! There are items to make it better, make it last long and obviously make more power....but they aren't needed. Things i would recommend you have on our short list however, as they will aid with tuning and safety.
1- a WIDEBAND (no, the narrowband you saw on ebay won't work) Air/Fuel gauge, this is a must for tuning
2- spark plugs (i REALLY like the Autolite 103's, especially in the beginning while tuning. They are UBER cheap, and work well, easy to gap also)
.....that's it, for the long list i'd add:
3- oil temp OR pressure gauge (dont' see the need for both, and no your stock gauge doesn't do anything. this is only to see problems sooner, nothing else)
4- boost controller (DO NOT ADJUST BOOST!!) A boost controller will aid in how the boost comes on and levels off, feels much better. i suggest a manual controller in the engine bay that you CAN'T touch while driving)
.....There are other things, but they are not turbo related, they are performance related. (things like limited slips, clutch/fly, better rubber). you DO NOT need a turbo timer if you have any common sense, you can, but you are just spending money.
This is all the basic info on the setups that i could think of. For the most part, an 8psi intercooled kit on a STOCK 6i MTX in the 225whp range, the ATX (6psi) at just over 200whp. Power will be increased with an exhaust, which most have anyhow, but it's not needed to enjoy boosting.
notes for the ATX guys:
'03-'05 6i's with the 4spd have an off the shelf option to upgrade both their valvebodies and torque converter from Lentechautomatics.com, or whole tranny if you'd like. The valvbodies help out an amazing amount, and allow for a bit more boost if you want, the converter allows for a higher stall speed which is nice if you powerbrake often (the strip) and they can also remove the lock-up setup which can be a bitch when having fun on highway cruising.
'05+ 5spd ATX's have faster/tighter shifting out of the box, so that is a nice start. If valvebodies are something you want (as they can be improved quite a bit), Levelten.com has experience with them, though you need to remove yours and send it to them for the work.
Both models- please take a minute to understand how your ATX works, and then understand why i say you should always let your foot off the gas between WOT shifts. It is not something that will brake the tranny in one time, but please understand it's not recommended as the boost is still being applied while the tranny is trying to shift. Also, for the same reason, if you are cruising on the hwy while the converter is in lockup, DO NOT just slam it to the floor, it's not good for it either, a quick blip or downshift will safe a lot of trouble.
Now, i know of roughly 6 turbo'd 6i's that are (or have been) daily drivable, there are currently 4 on this forum actively i believe (as of 6/09). I would imagine all would attest that it's a friggin blast to drive, and the smile doesn't leave your face! The car is still pretty light at just over 3k, so the addition of 80-90WHP (about 60%) makes a huge difference in feel. But keep in mind that it costs roughly $5k on the low side for the setup, which is anywhere from 25-50% of what the car is worth, premium gas is required now, and it's hard to go back to stock if you think it's temporary. In the 4 years i've been turbo'd and talking to people about it, i've found that if your plan is more than 6 months (it's more like 3-4) out, then you won't get it. If you have 90% of the money in hand and are serious, go for it, but if not, there's not need for a billion questions that don't go anywhere, please just read what's on here already and enjoy the dream (it's cheaper!)
This link will always show you all the current topics for turbo's on the 6i's:
Turbo threads
here's a few vids that have been around forever, but if you are new you might like them.
Reactions: 1
101 - 120 of 164 Posts
Boost is just a reference and does not dictate power potential. Airflow...better know as CFMs is what dictates actual power making for the most part.
8psi from a big borg warner turbo will make shit ton of more powr than say 8psi from a K04.
What stops people from getting a huge turbo, better intercooler and making the most power possible, thus calling it a day?
Money is what stops everyone from doing something they want in most cases. big turbo and intercooler only produce and cool the air charge.....it takes an engine and tuning of that engine to produce the actual power.
...then there's the whole, power getting to the ground thing, so trans comes into play as well
Wow...didn't get an alert for that last post you just answered Tea. But I agree 100%. Tuning is huge. And I get upset when people try to run power adders without some form of tuning. Can it work? At times...Sure. But not optimally.
Do it right the first time or not at all is what I usually say.
Hi Im new and was wondering if this is the kit I wanna get for my car: https://www.gp-werks.com/products/Mazda-3-Stage-2-Turbo-Kit-2.3L-04%2d09-(comp-turbo).html I don't see a mazda6 kit but I know they have the same motor.. thoughts? also what Do i need for ecu or tuning? Thanks!
That kit was never released for the 6, which is why they don't list the 6. It was on my car when I sold the car back to one of that companies developers, so they might be able to help you out if you email them. tuning was never finalized with them on the 6 that i know of, so that would be something you'd have to tackle on your own i'd imagine.
I have tuning available for the 6i's. As I have said.
yeah i emailed them like 2 weeks ago and they said they just got a car so in a couple months or so they should have a kit. thanks for the reply
saw the car yesterday, just trying to get the car with the list of mods in my sig....back to stock, so the kit can be finalized with everything sitting in the right/stock spot. will take a while i'm sure as trans/axles/mounts/exhaust all have to be sourced before it can happen.
Hey guys, I need some direction….. some info would be great!
I’m really interesting in turbo my 04 6i; I have not done any mods, yet.
I really like this kit:
cxracing.com: 02-08 Turbo Intercooler kit Mazda6 2.3L Bolt on TD05-H
I’m about 85% sure that I’m getting this kit. I have a few questions:
1) Any thoughts on the kit? Good or bad. It’s an average kit, I know but I’m trying to get a nice setup and not spending more than $2500
2) Can I get just a cat-back system (magnaflow) to use with my OEM catalytic? Or should I change that as well?
Thanks in advanced
1) id spend the money, and build my own kit out of much higher quality parts at a better price.
2)yes, you can do that fine. but if your going turbo, your probably going to have to get a larger cat also.
Im trying to find another motor right now so i can start ordering the bottom end my biggest thing is i cant find a intake manifold that will be able to hold up to boost and spray at the track any thoughts? Looking to be able to (on a track day) run at least 15lbs with a probably just a 100 shot
You have a tuner? That's the only thing that's stopping me for turboing my car.
Sent from my Autoguide iPhone app
You can use Justins PowerMod piggy back ECU or you can attempt MehaSquirt2 if you have electronics knowledge. I ran MS2 on my 2007 6i for a while and used it at the track too.
My friend told me to stay away from the megasquirt.
MS2?
MS2?
Megasquirt 2. Everyone on the forums told me to stay away from MS2 as well but I got the car to run and used it at the track.
I personally really like the ECU but you definitely need to know electronics and the 6 WELL to get it to run successfully. From my understanding I'm the only one to date that ran it successfully on the 6i.
Jan
Im just wondering what I can run with my 2008, if I turbo my car.
4
I think the 2007 (mine) and 2008 (yours) have the same engine timing marks and therefore you can run Megasquirt 2. As long as your crankshaft trigger is a 36-2-2-2 wheel you can run MS and have it control fuel and spark. However, I stress you MUST have a technical background since MS can be overwhelming since theirs no documentation for the 6. You'd need to do a lot of research and testing to determine how to wire the MS2.
Here's a picture of the 36-2-2-2 trigger on the crank (in the pic you'll notice the long raised edge, our 6 has a long gap without the raised part, but it's the same trigger) then a picture TunerStudio showing Megasquirt2 decoding the trigger wheel and finally the car running at the track with it:
Also, here's a picture of tunerstudio run on the 6:
Uploaded with ImageShack.us
so it seems like all the resources are here, now my only question is how did you go about routing your piping? I went under the hood this morning, and it doesn't seem like there's any room to work with. I mean there's no room to the left at all, and the TB is on the right with only enough room for the incoming pipe... everything else seems pretty much spelled out. (thank you mrTea and TGNY)
there's tons of room for the piping once your stock airbox and battery is out of the way. and people have done it just fine even with keeping the battery in the stock location. but that will be a little more work to pull off.
Reactions: 1
