1 - 3 of 3 Posts
Hey guys, bought a clutch kit for my 04 Mazda 6 V6, wheels are on, everything is almost back on. When I push the clutch in, no sound, when I release the clutch it makes a clicking sound, then goes away, if I hit the release point then let the clutch out it makes the same sound (out of gear) . ( I dont think I have all the air bled out of the clutch) but I dont think it would be making this sound if there was air in there would it? Video below for the noise/sound.
The car is on jacks right now, in gear with a little gas given it makes no sounds.
https://youtu.be/f0pNt20J2mQ
I couldn't really hear the sound here. Does it only make it when the car is running and I'm wondering if you are going to hear anything when the car is off the jack stands and actually engaging/moving?
Scott
Turns out im just an idiot and did not notice 2 sensors plugged in. Went through everything to be safe and located to sensors on the transmission that I missed. Plugged sensors in, all set.
1 - 3 of 3 Posts
