So like the topic says, I have an '05 6S ATX (6-speed) and am wondering what transmission it has. I've been looking into a transmission cooler and filter and bulkpart.com has a list of possible transmissions:
Bulkpart.com
Which one do I have?
Bulkpart.com
think its called "the Jacto"...or something of the sort...a more reputable source will post shortly.
you have the AW6A-EL It is not a Jatco ATX, I dont think. DO NOT mess around with the ATF you put in it. Make sure you use the proper fluid.
http://forum.mazda6tech.com/about8.html
Right, got that.
http://forum.mazda6tech.com/viewtopic.php?t=8
You have an Aisin-Warner transmission (AW6A-EL). I don't see any parts for it in that site. I suggest getting a B&M cooler from SummitRacing like the rest of us. Also, the filter is part of the pan and is unserviceable. Instead, a number of us install Magnefine filters inline with the cooler.
EDIT: D'oh. Badtlc was quicker on the draw!
So: BMM - 70264
And: Magnefine
With the Magnefine, is 3/8 inch correct? And what are "Smart Connects"?
