You need to remove part of the intake manifold, the plastic part that holds the air filter. I'm not sure if this is applicable across all models.
I should have taken pictures...
How do you check automatic transmission fluid level.
I see you posted in the 1st gen ATX section depending on the exact year the top will be orange or black if you look at your battery the dipstick will be just to the left of it the recommended procedure is to drive the car get it up to temp then park it shift through all of the gears p,r,n,d then back to park doing the same thing and check the level
Do all 05 wagons have the 6 speed Aisen unit?
