1 - 3 of 3 Posts
I just installed my Trans cooler then went and had a complete fluid flush, now im going to go back and put in an inline filter, i read that alot use the Magnefine, so i was going to order: http://www.emergingent.com/magnefine/order_page.htm the $19 3/8 inch one. as an option it has 3/8 smart connects for $3.50, what are those? also the hoses i have now are the 11/32 will this be a problem with the 3/8 inch filter?
- SLCAtenza
1 don't get the smart connectors, I did and its not needed. That hose will be a TIGHT squeeze to put on albeit it can be done.
Ya i just read on their site that the smart connects are for steel tubing, since we use rubber i didnt order them. As long as the male connectors will fit into the tubing i dont mind, the size difference between 3/8 and 11/32 is damn small so i guees will try by trial and error. thanks for info.
1 - 3 of 3 Posts
