1 - 9 of 9 Posts
I was going to order the B&M tranny cooler, the 70266 model, but i could not find a 19,000/24,000 gvw cooler that comes with a kit on summitracing.com, i only see the smaller one. Is there no kit from that site or should i just buy one at pep boys or something?
When I ordered my B&M from Summitracing it came with a full mounting kit in the box. All you need from that kit is the 2 brackets (and bolts/nuts) that mount to the latch in the front. I wouldn't use the hoses that come with it unless they changed them for stronger ones. I would get them from Advanced Auto or Autozone since they're thicker and more sturdy.
I just checked summitracing's site and they had all the coolers listed on bmracing.com.
There all there, but the cooler i was going to order, stock # 70266, say this does not come in a kit. i only see one that has the kit. and its the smaller version. THe brackets are really the only thing i need but the autozone near me didnt have a install kit or the bracketts, i havnt check Napa or pepboys as of yet though
Ok yeah, I just looked that one up and it's one of the racing models, that's why. Any reason for going with such a big cooler? It's 20,500 btus which is overkill in most situations. I believe the 24,000 gvw is actually only 14,400 btus (part #70264).
Oh really? I was mi-informed then, I read somewhere that that part number was the 24,000 gvw on the board somewhere, I did notice it said racing and that it was like 8.5 x 11 which was quite big. Ill look for the cooler you listed, thanks!
I went with the B&M 70264 (listed on BMRacing.com as 14,400 BTU) from SummitRacing.com
I just typed in "70264" in the search bar, and it returns the product with the kit. Hopefully this link will work, and isn't tied to a cookie or my session.
Looks good to me, just placed the order for the 70264 model. thanks for the info.
I'm not sure about the quality of the hose, like the above poster mentioned, but you will need to pick up some more hose from a local place. The hose provided gave enough length to get from the tranny to the cooler, with a little extra. I, personally, picked up another 4 feet of hose from AutoZone, and used that to go from the cooler back to the tranny. Was a fairly easy install (little too long if you ask my girl).
1 - 9 of 9 Posts
