It would be even LESS okay in that instance. For racing tires, you want the widest wheel you can use for a particular size. You can mount a 235/45R17 on the stock 17 inch wheel, but it will be pinched down and performance will actually suffer as a result. This will also lead to premature failure of the tire due to cracking of the bead and/or shoulder area of the tire and uneven wear. This is why 235/45R17 is not recommended for the stock wheel. That's why so many people are using 225/45R17.I'd only say it's ok if you were running a VERY stiff walled race tire.
So, what's your point, 6 speed 6? Just because Joe Blow at the auto-x does it, it means they know what they're doing? And you don't see Toyo at your auto-x's because we don't make an autocross tire. Ours is a road racing tire designed for spec series. Go to a NASA event and you'll see lots of RA-1s. So don't hand me any b.s. that "no racer likes Toyo." :sarc: Please. Oh, and the Speed Channel Touring Car and GT series uses the RA-1 exclusively, which is an SCCA professional series. If you have something against Toyo, just say so.I've never seen a racer put anything but the widest tire they can fit on the rim. go to a local auto-x and look what crazy stuff people are putting on their 350Zs for example. Around here we have them putting 285s on 7.5" wheels. And no racer likes toyo's. they're not anywhere on any of the top 10 SCCA cars in any class.
Hey, who am I to argue with you and your autocross buddies? Obviously you all have discovered something that tire engineers have been unable to discover. I'm quoting other pages to back up my assertion. What do you have to back up your argument besides anecdotal stories about your autocross buddies?well considering the joe blows compete on the national level I'd trust them to know...You can keep quoting web pages all you want but the fact is that most racers will run the widest tires they can fit on a rim.
Obviously, you do have a problem with either me or Toyo, because the original question was whether or not a 235/45R17 would work on the stock wheel and when I corrected your post about competition tires in that size on a 7 inch wheel, you come back with an insult about Toyo. What did that have to do with the original post?These same guys also race NASA events and these same guys think toyos are out classed by the other tires.
and as far as a series running toyo tires, they'd run any tire that was willing to support the events. They only all run the same tire because the rules say so. You know that if it were up to the teams, everyone would run the tires they want, not the tires they're forced to use.
I don't have a problem with toyo though. I think they're ok tires. But they're not the best and I think you're head has grown a little big.
Well, it should! It would certainly make you more of an expert than me. And considering my job is to know about tires and I have lots of experience testing and racing on them, and I've been in the tire industry over 17 years, it does make me an expert. Maybe that sounds cocky to you, but after all these years, I'd better be an expert, or I'd be out of a job. And I don't pretend to know it all, there's plenty of subjects I know nothing about and I'm not ashamed to admit it. But I know tires. :yesnod:I work for the only shipyard that builds aircraft carriers in the US but it doesn't make me an expert on them. [/b]
Yeah, but in this thread, toyoguy is right on. (And probably surprised to see me agreeing with him.)Ouch! Just damn...OUCH!
Actually they do know what they are doing: getting the most rubber on the ground possible. Longevity is not what they are after.So, what's your point, 6 speed 6? Just because Joe Blow at the auto-x does it, it means they know what they're doing? [/b]
Actually the T1R (a good high performance street tire) is eligible for the Street Tire classes in SCCA autocross but to date no cars have trophied or even entered at the SCCA Solo II Nationals on Toyos.And you don't see Toyo at your auto-x's because we don't make an autocross tire.[/b]
*faints*Yeah, but in this thread, toyoguy is right on. (And probably surprised to see me agreeing with him.)
Hey, I'm all about getting the most amount of rubber you can on the ground. BUT, if you're not putting that wide tire on the proper width wheel to maximize sidewall performance, then you're wasting your money. It's a common misconception to put the widest rubber that will fit on a particular wheel. And here posttosh and I will agree: you must put the proper size tire for a particular wheel width to maximize the tire's performance.Actually they do know what they are doing: getting the most rubber on the ground possible. Longevity is not what they are after.[/b]
Although the T1R may qualify for the Street Tire class, it was not designed with autocrossing in mind. When I say we don't make an autocross-specific tire, I'm referring to tires that other manufacturers make, like Hoosier A6, Yokohama A008RSII (no longer produced) and others that have/had compounds specific for the demands of autocross. Road racing tires have very different compounds and construction. Toyo's RA-1 is optimized for road racing and we don't make an autocross-specific tire. Other than that, you are correct.Actually the T1R (a good high performance street tire) is eligible for the Street Tire classes in SCCA autocross but to date no cars have trophied or even entered at the SCCA Solo II Nationals on Toyos.
Other than that, you are correct. [/b]
well considering the joe blows compete on the national level I'd trust them to know. These same guys also race NASA events and these same guys think toyos are out classed by the other tires.
I don't have a problem with toyo though. I think they're ok tires. But they're not the best and I think you're head has grown a little big. I work for the only shipyard that builds aircraft carriers in the US but it doesn't make me an expert on them. You can keep quoting web pages all you want but the fact is that most racers will run the widest tires they can fit on a rim.
