Hello everyone, been awhile since I been on the forum...
ANYWAY... I recently test drove the new 2.5T 2018 6 and here are my impressions...
1. The power from a stop is very good, a lot of pep. However, in the midrange, it seems as responsive or less than the 2.5 NA. Could be attributed to the transmission and a downshift on the paddle shifters actually helped.
2. The interior is gorgeous! I still like the layout on my 2014 a bit more, but the middle of the pack Grand Touring (which is weird, it used to be the top tier) was very nice. I did not get a chance to see a Signature trim, but I am sure that is even nicer.
3. I do like the new grill. And that's about it exterior wise. The new bumper is meh and I really am not a fan of the rear end. Oh, and those wheels are terrible.
Honestly, while it does have a more powerful engine, I still prefer my modded 2014 6 over the new 2018 turbo model.
What say the rest of you? Anyone else took the new 2018's for a spin?
LOL. Yep, doing a-okay, got some mods be adding to the car soon.
Thanks for the insight Chazzy. The Mazda salesguy who went with me did indicate what you mentioned, but he said it was based on going the higher octane that power really comes in. What about the mid-range? Does it feel responsive after breaking it in?
I do want to caution on the test drives here guys. There's a programming curve at play here on these new cars. Coming from the 2.5L OVTuned world, I understand how the engine works when it gets flashed for 93 Octane. It's a complete dog for the first 100 miles while the knock sensors adjust to their new standard of operation. While the programming ideology is nothing new, you do have to know what to expect from a motor that functions with these dynamic programming methods.
When the new 2018s arrive on the lot, the ECU has no idea what kind of fuel is in the car since Mazda went the route of dynamic knock sensors. So over the time, the ECU first puts the ignition timing at a safe level when it arrive on the lot, and as miles are put on the car, it incrementally adjusts that ignition timing to create more power. It will continue to incrementally adjust that timing until the knock sensors determine threshold based on the fuel.
Suffice to say, when you test drive one of these new 2018s, the power your experiencing, is not the actual power the engine puts out, so don't let it fool you. I will say, I was thoroughly disappointed in my test drive until I realized what the motor was doing. Today, with 800+ miles on the motor, I will say that thing is a different animal than the one I test drove -- granted I'm using 93, but the same theory I described above is true with 87. The engine has to first determine what kind of fuel you're using before it can really wake up.
Just something to keep in mind when you're going for a test drive on these. Case and point, I could barely get the tires to spin from a stop, and now I can light them up in first gear. It's quite an amazing difference
Hi Chazzy. Wondering if this learning curve would affect redline? I recently drove a 6 with about 100 miles on it and the redline was lower than what was indicated on the tach.
A few miles? And thousands of knocks if full throttle were used? Sensors work instantly in real time.
Timing being "optimized"? Optimization sounds like a setting. Timing advance is a continuous activity that changes in milliseconds in response to many factors -- load, rpm, and onset of knocking. I can watch it on the ScanGauges in my cars.
ECU "learning" to stop knocking after a few miles? What is the purpose of that, and what is it waiting for? Such a delay function could be designed into the ECU if there was any benefit, but there is only harm.
People add 10 gallons of 93 to 6 gallons of 87 in the tank, and expect to feel a difference. But the extra power from the resulting octane can only be felt at near-redline rpm. There is no effect on torque.
I will bow out of this one guys. I have hands-on experience in working with the 2.5L and it's characteristics and behavior before you as the driver really feel what you're expecting to feel. I try to explain it in the proverbial 5th grader terms that everyone can understand.
It would appear this gent wants to troll and get as ridiculously technical as possible though. That said, I refuse to get in pissing matches on message boards, not worth it. So hopefully a majority of you understand that at the very least, the performance you feel on a test drive in these cars is not indicative of the performance that will be achieved once you have some miles on it.
Cheers to all, I will let this guy explain to you the quantum mechanics, fluid dynamics, and spark control of these engines.
There is no doubt a new engine will perform differently as it breaks in which is why I personally won't buy any vehicle that has been out on several (one) test drives by another person. That's just me....
I have noticed this engine has noticeably changed as it's now passing a 1K miles. Much better feel, performance and gas mileage.
Without the technicalities,
The knock sensors are instantaneous. They adjust "on the fly". This does not mean that the additional HP is felt immediately as they are in a constant learning mode however it really is only a few moments that the engine is running in it's optimum state. Actually, it's always runs in it's optimum state.... but it does relearn when changing the octane. Whichever octane you run is fine (as long as it's at least 87). The engine will deliver max performance (HP) with the higher octane because of the way it burns/ignites not because it contains "more power". Octane will change the "sensors" readings whether the timing should be advanced or retarded, hence the performance changes. Remember we're not talking about monstrous changes here. Most people probably wouldn't notice the difference especially in average day to day driving. Keep in mind this is much more true of forced induction (turbo's) than that of a NA engine.
Now if someone wants the physics of how and why all this works a debate/facts thread would be very interesting!!
The ECU does make fine corrections to timing across specific load and rpm ranges, based on knock events under certain conditions. The ECU is programmed to remember knock events and what caused them. The ECU uses this memory to constantly adjust an ignition advance multiplier, which is used to determine the amount of advance to add to base timing. Perhaps this is what is meant by learning.
Ahhh yes, it's always rewarding to read a well written, thoughtful and poignant comment that enhances the value of a thread.
We all look forward to your continued participation.
Ever since I got my 2018 GT Reserve, I've been lead heavy with my left foot.... My mpg is suffering because of it... I went from 33 mpg from my 2016 Mazda 6 GT to 28 mpg....
I CAN'T HELP IT!!!! I'm constantly looking for an excuse to drive it all the time! It's pretty much the most HP car I've ever owned and I'm wasting so much money on gas because I'm only putting premium in it. Oh well I guess I can live with that as long as I get the speeeeeeeeeeeeed!
