Good day! First time posting, but have lurked some. I'd like y'alls thoughts on what could potentially be broken.
After a recent trip, I started hearing a noise that I couldn't place. After 20 mins of more driving and getting off the interstate, the sound was more evident especially when accelerating. I pulled off to an autoparts store, and checked oil level (among other things). I was low. After about a 1.75 qts, oil started showing up on the dipstick. I had been about 7000 since the last oil change, so I was due (I change every 5000 miles with Castrol Edge or Costco's Kirkland). I kick myself now for not changing it sooner. I'd have seen the lowered oil level.
EDIT: The check engine light nor the engine oil did not come on. The auto parts store scanned as well, but there were no codes (with their basic scanning tool).
I drove back (about 2 hours worth of driving), trying to keep RPM under 2K. We listened around the top of engine with a long screwdriver, and there was some noise with the belt tensioner. So, I went ahead and replaced that (plus belts were still original). It made things a little quieter overall, but didn't reduce the knocking sound.
So, I'm at the point where I'll probably call a couple shops around to see who can take a look. Any thoughts on possible culprits to try to get some initial quotes?
Some background and observations:
Year: 2017
Engine: 2.5L (non-turbo), MTX
Mileage: ~96k
Powertrain mods: Axel back exhaust
I did an oil change yesterday, and noticed the oil was glittery. I took apart the oil filter, and there's metal shavings in almost all of the pleats, so things aren't looking great. The shaving don't appear to be magnetic. Example below:
Here's a couple videos of the sound, from inside and outside.
Inside/driving:
Outside/parked (slow sustained rev up to 2000 RPM):
Year: 2017
Mileage: ~96k
- Sound seems to be most evident when giving light/partial throttle, starting around 1500 RPM up to at least 3000 RPM. Sound does not occur when releasing throttle at those engine speeds.
- Sound occurs with clutch in or out.
- Belt tensioner, serpentine belt, and water pump belt were replaced yesterday.
- I'm not sure where the 1.75 quarts of oil went. I didn't see leaking from the oil pan plug and oil filter, nor any stray oil on the underside panel cover. Maybe I'm just burning oil?
Inside/driving:
